Who runs 36"s on D44??
78Scronco
Trying to get an idea of how many people run 36's offroad on stock d44. pics also include what size lift. thanks!
Madgyver
Bronco Madman
77 EB dana44 with 37" MTRs... 5.5" SL, 1"BL, flares cut to bodyline, cut rockers, bobbed corners..
BroncoJAK
Just installed these. Haven't run them yet but it looks like I may have some rubbing. 3.5 suspension 2BL.
78Scronco
78Scronco
how many broken axle parts do you guys have wheeling? I know this is a general question and depends on alot of factors. But I'm trying to decide if I can run 36 tsl's on stock eb d44 without it. I'm used to big stuff on full size broncos so this is taking a step back for me as far as strength goes. thanks
Madgyver
Bronco Madman
I'm still running the stock axles and the u-joints are ready to go.. I do have chomo shafts ready to go in.
Tito
CB Fire Starter
Bakersfield, CA
I think the 36" swampers, 37" big brand tires are the cutoff for the 44, thats what I have come to see and experience. I guess thinking about it the broken stub came when I was running my 38's (they were my street tires and decided to enroll in a rock crawl comp at the local Jeep dealer). 36" Irok's are my wheeling tires. And if you are going big on the lift split the difference between the body lift and suspension lift to help with driveline angles, otherwise at least cut down a HP D44 for the front. I have seen a lot of people with either real expensive front shafts or having issues while running the 5.5" susp lift. I know Mad gets away with it but then again he gets away with a lot more than the rest of us ;D
Hal9000
Flagstaff, AZ
I guess thinking about it the broken stub came when I was running my 38's (they were my street tires and decided to enroll in a rock crawl comp at the local Jeep dealer). ;D
Ouch! You broke while competing at a Jeep Dealership? That's no good!
1sicbronconut
Pic's in my gallery. I've run 37" MTR's for about 4-5 years with a Dana 44, warns axles with CTM's. Been on some of the tougher trails the South West has to offer. Broke one outer in Las Cruces when I was backing up under hard throttle. I agree with most folks 37" tires are about it for a Dana 44 and depending on your rig and driving style they might even be to big.
Tito
CB Fire Starter
Bakersfield, CA
Hahaha, serious!!! At least the year before I did have the best score till they brought out the competition buggy, that wasnt fair at all. I broke this past year but the Broncos did win all the categories at the Jeep competition...I'd have gotten the hard luck award but I had to drive home (had my 2 little boys with me and it was nap time).
broncomitch
west jordan, utah
i ran the 36'' tsl radials for a about a week then traded then for the 38's had to trim a little on the corners.
im running the stock shafts and have not broken anything yet.
t.lay
Grayslake, IL
I've got 36 TSLs, d44, stock axles, cheap u-joints. I pretty much expect to break something at howiepalooza
recoiljunky
Dothan, AL. USA
I'm running 36x12.50 TSLs on a stock D44. My ride doesn't see any rocks though, only mud. I also don't have a lot of time on the TSLs, so we'll see.
ugly_od_eb
Moyock, NC
pffff.... i run 37"s on my D30 with a trutrac and 4.56's lmao not a single problem in 4 years. But it does scare me ?:?
david heater
Westminster,Co
I run 36" swampers on mine no problems yet, I have a 3-1/2" lift and a 2" body lift. Cut the the wheel wells for gorrilla flairs.
I run warn axles with ctms.
ufospy
Elk River mn
I run 38's and have no problems <a href="http://good-times.webshots.com/photo/2787035340103635915flWgze"><img src="http://thumb15.webshots.net/t/66/566/0/35/34/2787035340103635915flWgze_th.jpg" alt="DSC00057"></a>
NC-Fordguy
Bethel/Greenville NC
Running 37x12.50x15 PJs with 3.5 suspension lift and 2 in body lift
Broke a right front u-joint and left rear axle shaft at the same time. Ditched all of the stock stuff and now running dutchman front shafts and yukon 35 spline rears. Never had a problem with the stock stuff when I was running 33s
Here's a pic right after it happened. Winching up to a flat spot to do repairs. Those of you who wheel around here, this is the first ledge on Daniel at Uwharrie
FerrumCampitor
Hutchinson, MN
Have wheeled 33x12.5s on a Dana30 for years and never broke an axle or axle u-joint. Have exploded the carrier twice though (2nd time was bad setup I think). I just put 35's on and we're going to give it a whirl with the new NP435 turning them. I have a Dana44 sitting in the weeds waiting for the day I break my 30 again. I figure if I can make my 30 last this long with the things I've done, I can make the 44 last a good while too.
I know several guys running 36x14ish sized tires on a 44 with no more issues than somebody running 33s on a 44. But they all run automatic transmission which I think makes a huge difference in how well your axles hold up. That torque converter takes a lot of pain out of the axles.
