broncoboy71
Thanks looking at replacing my stock hinges with lift off higes
Check out the stainless hunges at all for fun offroad before you buy. They look to be 3/8 pins with oil impregnated bushings.
www.broncobob.com
Is that why the stock ones last so long and work so well ?
Hinge pin size is a little bigger deal then you think. When you are lifting that chunk of solid cast iron we call a door onto the pins, trying to shoot double bullseyes getting both pins to line up it becomes a big deal. catch one pin and not the other and you have all the weght of the door balancing on the tip of one of those pins. It is a bit nerve racking trying to do it and keep yourself from screwing up
Sam at Wild Child http://awildchild.com/door_parts.htm was the first to market lift off hinges and I have been running them for years. Maybe no bling, but they mounted up easily and have worked great. There are going to be alignment issues no matter who's you use and if they tell you different they are FOS, that's just the nature of hanging doors.
1/4 inch shaft size is plenty of strength and I can have both doors on by myself in minutes.
Everyone else stole Sam's idea and I like the idea of supporting the inventor.
My .02 cents,
