- Jun 4, 2002
- 35,283
My 9" is leaking again. But for some reason I don't have the normal leaks. I saw drips of oil on the ground under the rear end while I was starting to install the new OX joints up front. So I went to the back and looked. I figured that I got a little sand in the pinion seal or something like that. The front side of the diff was dry. Then I figured it was the third member gasket, nope that was dry.
Found the oil leaking on the back of the passenger side where the back cover is welded to the banjos. I just got through fixing a cracked weld on the drivers side in front of the axle. Those were cracks of there own, the hole I ripped in the passenger side axle with my first generation torque arm is still patched and not leaking.
I may have to break down and get a new housing. Not sure how many more times I can keep patching this one back together. Why can't I just have a normal oil leak from a seal or a gasket?
