Cross-drilled / Slotted rotors are holdvers from an earlier time of brake technology. People needed them on "race cars" at one point and imprinted on the concept - they are all show these days and no go.
Pad gassing simply doesn't happen any more with today's compounds. Pad glazing is no longer an issue either. Due to these factors, neither drilling or slotting provide benefit for the average consumer.
There was a great discussion of this over on
corner-carvers which, if you're willing to wade through the swearing and abuse, discusses at great length the way brakes work and what genearlly works best.
If you changed your rotors and found you're braking better - did you change your pads, too? Probably. Further, your pedal travel is going to be shorter and feel firmer, particularly if you bled the system at the same time.
Yes, cross-drilling is available on Porsches. This is primarily because the people buying the cars *want* them. Most porsches are not driven on the track nor at the limit of their braking abilities. Most replacement rotors sold to the high performance consumers, people who take their cars on track and require maximum performance and heat dissipation, are not drilled or slotted.
Sure, you see a few of them on track days - most of them are cracked. Chamfering does help, particularly compared to the older methods of producing the rotors, but they will not last as long as plain rotors.
A disc brake rotor does two thigns for your braking system:
1) provide friction surface for the pad
2) act as a heat sink
By reducing the friction surface available, you're reducing efficency. By reducing the size and capacity of the heat sink you're reducing braking capacity and efficiency.
Vented rotors, a whole different thing than slotted or drilled, do make a difference in terms of cooling. They are designed to draw air from the hub and out through the edge of the disc to cool it. Drilling these rotors actually *reduces* their air pumping capacity and reduces their ability to cool themselves.
Simply, there is no reason, other than looks, for a 30-year old truck to have anything but vented rotors on it with high quality pads and fluid. You will get better performance, pay less, and your parts will last longer.
