Why two fuel pumps?
coreyvan77
One thing I've ran into before is that if your electric pump fails, it does not allow gas to the mechanical pump. Just another thought.
fiscus
montreal, QC
I think if you have an electrical inline as a backup the pumps should each have bypass plumbing with valves so you can close off the one you're not using.
Spot
Spot
Seattle
I never heard back from the PO so I assumed it was for redundancy. Regardless I removed it over the weekend. Took it out and just popped in an inline fuel filter in its place so I could use the same fuel hose. Runs great. Fired right up this morning after sitting all night. Problem solved. Thanks for the input.
