Painting Instructions
1. Sand edges and seams completely.
2. Wash all surfaces to be painted thoroughly with TSP in warm water and Scotch-Brite pads.
3. Sand surfaces to be painted with 320 wet dry sandpaper. At this point, you should have a dull scratched appearance.
4. Clean surface and all edges with either DuPont 2319S or Sherwin Williams R7K157 or R&K158 or equivalent.
5. Apply adhesion promoter or equivalent DuPont 2322. Some painters prefer, after cleaning the surface to apply DuPont
“Variprine”. Let dry and scuff with a Scotch-Brite pad and then apply basecoat/clear coat.
6. Apply basecoat/clear coat following manufacturers recommendations for painting a flexible polyurethane paint. Consult
your local paint supplier for the best materials to use in your area.
