Well, let me back up a bit for clarification.
This may or may not be apples to oranges, but more of a "check to verify -vs- assume they work"
The wheels I have are 1977 Keystone Turbos in 15 x10, 3.75 back spacing, which was in a year that most if not all of the trucks had disc brakes as new.
Those wheels DO clear the GM disc conversion I have.
Now as to what Ford brake set up they DO NOT clear on is the 80's up FORD set up.
I don't have a 76-79 set up to test it out on
The clearance issue was the caliper body itself and not the tie rod.
The wheel would go on, but would slightly contact in caliper area and drag and would have worn a slight groove in the main wheel hoop.
Given that, Even though the fitment interference may not apply to 76-79 I would not assume that all EARLY disc brake wheels were the same. I would attempt to verify before buying early disc wheels.
