msweb
- Aug 29, 2003
- 2,377
I now have my Warn 9500HS mounted in a cradle so I can use it in the front or rear of the Bronco. Specs say @ 9500lbs of pull it's pulling 425 Amps
I doubt I'd ever actually have to use the winch to pull that much weight but I don't want to go smaller than I should when I run the cable.
What is the minimum size cable I can use to run to the back of the truck and since it's coming directly off the battery, how in the world do I fuse it?
I've seen the Warn quick connect kit (http://www.warn.com/truck/mounting-systems/quick_connect_kit.shtml) but don't understand it. The plugs they use are only rated at 175 Amps? What is the "power interrupt kit"? The thing that looks like a solinoid? ?:?
Also - Warn says the ground cable must be connected directly to the negative terminal on the battery. Why can't I just bolt the ground to the frame and save from having to buy another 15-20' of cable? I also plan on having the hook-ups on my F150. If I need to go as big as 2/0 cable, the $$$ is gonna add up quick!
