77broncoAR
- Joined
- Nov 22, 2011
- Messages
- 3
What would you suggest for a winch?? if i went with a warn what lbs would be good??
8K minimum. You want the winch to have 1-1/2 to 2 times the loaded weight of the Bronco in pull rating. Most Broncos are 4-5 Klbs trail-ready. Keep in mind you only get the full rating on the first wrap - if your working off the top wraps (which most short pulls are) the actual rating is reduced.
When looking to buy a winch, somethign I learned just the other day (from this forum) is that Amazon.com sells Warn winches and you can get a great deal on them there.
Anyone else know of a good place to get a good value on a good winch?
You're not looking at the Ramsey RE series, are you?Warn is the most expensive winch...
There are several easy ways to multiply, amplify, or redirect a weak winch's power to extract a heavy vehicle, so take some time to read up on proper winch use. FM 20-22, FM 20-305 (Ch.21-22), FM 4-30-31, and the Field Expedient Recovery brochure (I don't have a link to it, or remember its number offhand) are excellent.
However... I am sort of "looking" for a great deal on a Warn 8274. Been seeing them go used in good working order anywhere from $350-$600. Gives you that classic look on the front of the EB too as a bonus. I'd love to permanently mount one on the front of my soon to be DD/ tow rig '71 F-250 crew cab 4x4!
