windsheild wiper splines
bronconut73
has anyone had trouble with the splines on the wiper arms being worn down? If so were you able to fix them?
Mine looked worn but they weren't.
Did the Rear Window Cherokee Wiper conversion arm and blade upgrade. They fit beautifully over what I thought were worn splines.
Photo maybe?
sykanr0ng
Unless you are doing a 100% restoration that seems to be a good reason to do the modern wiper arm conversion using the 'Cherokee' wiper arms.
You would get splines that aren't worn out and also bigger better wiper blades that aren't as hard to find.
