Windshield Dash Knob Repair
NashBronco
Flowood, MS
Does anyone know what size nut is needed for the dash knobs? I have some on order but want to go ahead and get the repair started before they arrive.
Mine were rusted out. I plan on using some eastwood internal frame coating inside to prevent as much future rusting as I can. It all feels pretty solid but I sucked up a bunch of rust. Any issues with that?
Beer and Fish
Are you going to weld a nut to the back of that? If not double up where the hole is only and tap it. ALWAYS use never seize on windshield knobs.
Beer and Fish
Looks really good though. Nice and clean. You could do the Eastwood if you've already ordered it or spray the crap out of iy with some canned oil, WD40 or something that you can get a tube in there and really soak it. How will you get the internal frame coating down deep without removing the windshield? Need compressed air and something rather thin...IMO
Beer and Fish
Quick question, were you able to retrieve the old backing plates? Long coat hanger with magnet on the end? I was able to clean those up and chase the threads and re-use them welded to the back of the new plate if I remember correctly...
NashBronco
NashBronco
Flowood, MS
Yes, I plan on welding a nut to the back of the plate. I found the old plate inside but its not in good shape so ill just go the nutsert route.
The eastwood frame coating has a 24 inch spray tube that comes with it that I plan on sticking down the channel. I have tried to clean it out as much as possible to get the loose rust. I used a coat hanger to try to knock the small stuff off.
