Here’s how I replaced my hinge and a/s frame.
Fold the w/s frame down to rear on the hood (I laid a moving blanket down to protect the hood)
Disconnect and remove all w/s wiper parts and wiring.
Drill out each spot weld holding the hinge to the cowl. Edit to add - use a spot weld cutter not a drill bit at this step.
Using a piece of flat bar stock with one end sharpened into a sharp edge, i separated the hinge from the cowl by using it as a wedge and hitting end with a ball peen hammer. (Be careful not to damage the cowl)
Once separated, clean up the cowl with a flapper disc on your grinder (120grit works well - 80 grit too aggressive)
Inspect the cowl carefully for rust and repair it now.
Test fit the hinge to the cowl and w/s frame and as a full assembly to make sure they all work together. Happy with the fit? move forward. Not happy with the fit? Stop and figure out how to remedy,
Once happy with general fit and appearances of the pieces….
Using the new hinge as a guide, center the hinge. Mark and drill holes along the cowl and bottom of the w/s frame.
Install 1/4” nutserts into the holes drilled above. I think I installed ~12 across each piece the full width spread evenly. (Caution - make sure they’re offset or screw heads will hit and prevent w/s from moving into position!)
Test install everything using 1/4” SS button allenhead bolts. Make sure the w/s frame centers as you want and will hinge into the upright position.
Happy? Disassemble everything and paint it.
Not happy? Adjust/slot holes to get it where you need/want it.
Paint the cowl section and w/s frame.
Once the paint is dry, I used some of that gummy sealant that come on a roll (used to seal pipe penetrations through walls; comes on a roll) and laid a bead between each surface that gets bolted down (hinge to w/s frame and hinge to cowl).
Attach the hinge to thw w/s frame using your allenheads.
Lay the w/s assembly into place and bolt the hinge to the cowl.
Move the w/s into position. Still happy? Install the rubber w/s seal.
I’ll add some pics of the tools I made and seal I used for the hinge.
Go slow!!! Go very slow!
