Windshield frame hinge install
snipes243
Huntersville, NC
So I have done a bunch of research on installing the stainless steel hinge . I’m like 90% sure I’m gonna either rivet or bolt the hinge on. But through all the threads on classicbroncos I couldn’t find a single picture. So do anyone have any pictures on how they did it?
SevenT
Southern Colorado
Windshield Hinge
snipe243,
Check out the picture. This is how I did it, but I have fiberglass. I welded the hinge to the windshield and used the holes for spot welds as my match to drill the cowl. I had to use a plate on the bottom since it is not steel. The screws are 1/4x20 with washers and nylock nuts. The heads were beveled to keep the profile low in the hinge., Hope this helps.
v/r,
SevenT
needsmoarturbo
Thanks guys that’s what I needed. Second question has anyone used a rivet nut to attach the hinge to the body?
I think there was someone a month or so back that posted some photos of using rivet nuts but I can't remember poster. I commented on it, so if I remember when I get home tonight I'll post the link to that thread
72pabronco
Don't forget to put a small bead of silicone around the holes for the small bolts. It will leak in those pouring rains. Don't ask how I know:(
m_m70
Prescott AZ
I'm using rivnuts on my stainless hinge. Will use "right stuff" between hinge and cowl and regular gasket in the hinge. Hopefully will get the glass in tomorrow. Traveling next week to the Sierras and will see how well it seas %)!
SevenT
Southern Colorado
Windshield Hinge
72pabronco,
I used some Marine Sealant on the cowl around the screw holes to seal that area. I believe I got this idea from one of the original Bronco Design tub owners. I hope it seals well and keeps the water off of the electronics and my feet.
v/r,
SevenT
72pabronco
That was probably me. I was Bronco Design tub number 4. 8 years on the road 17k miles on the tub and not a single issue. Well except the leak around the windshield hinge. Not BD fault, that ones totally on me.
