windshield hinge
MonsterBIlly
so i lowered my windshield in preparation for the new dash pad I have coming. I was surprised to find that the hinge was not attached to the bronco frame. At one point the hinge was riveted to the body and looked like it had a seem sealer that let go.
I saw on the cj poney video the dude states that the hinge holes were for bolts but i think a bolt would prevent the hinge from closing.
So, how should i connect the hinge to the body. Should i redo the rivets? should i plug weld them and grind smooth? Would it be best to replace the hinge since i will eventually paint the bronco.
I m thinking about replacing the hinge and riveting it on for now so it will be easy to remove later when im ready to paint.
please share your thoughts
NC-Fordguy
Bethel/Greenville NC
66 models were bolted so it sounds like you have one. You'll need to create a gasket to go between the hinge and the body unless there is now one available. When I did mine 10 years or so ago I ended up using a bicycle tire intertube and a hole punch for the bolt holes
MonsterBIlly
MonsterBIlly
As stated in my post. It was riveted on. Not bolted.
I was wondering if it should be welded or bolted on. And if i should or should not get a new hinge
langester
MASTER OF MADNESS
I put a stainless steel hinge on my windshield frame recently. I used tapered socket head 1/4 -20 screws. I drilled holes in the windshield frame and the top of the cowl. My old one was welded top and bottom, I did not like fact that I could not remove it easily so I changed it. I used the heads of the screws to check the holes I drilled in the hinge to make sure they set flat. Worked out very well. My frame is at the glass shop right now so I can't take any pictures but I think there are some on my build thread. I will look and see if I can find them.
NC-Fordguy
You can do whichever you want. If you elect to rivet it or bolt it you'll likely need to fabricate a gasket to keep from having leaks. If you weld it obviously a gasket is not practical or needed. Just need to make sure the welds are good and watertight with no blow through or you'll be dealing with leaks that are now more difficult to repair.
ptwist
Langester, Where did you get the stainless hinge from an dare you happy with it?
langester
MASTER OF MADNESS
I got the hinge from WildHorses. It comes without holes so you can drill however you like. I like the fact that it is stainless, a little more money but I won't have to deal with rust anymore. I only had it on for mock up, as soon as I get my frame back with the new windshield I will seal both sides and put the new seal in between the hinge and I am golden. I don't see any problems with it for now and am very happy with the way it turned out. I should have it installed this weekend.
ptwist
I scanned the pages form my Body & Interior Assy. Manual. Hope this helps.
ptwist
Ya, The body manual is only for 66-70. But they didn't have a page for the 70.
rydog1130
The bolts heads have a low profile and the upper area is recessed so when it folds the heads don't interfere with the hinge laying flat
JB Fab
whether you drill/bolt, or weld start in the middle and work your way out.
Especially if you are welding a stainless hinge, stainless moves around a lot when heated.
MonsterBIlly
MonsterBIlly
Will do. My new hinge arrives today.
I am going to hold off in putting it in though. I will wait until i am ready to paint it.
I will use the existing rivet hiles for a truss head screw for now.
Thank you all for the info
DEEPWOODS
Hinge screws
This is what I use stainless steel 10-24 thread countersunk and undercut head they work great!
