wipers won't park
Lunar-tic
Brentsville
Situation: my wipers won't park. Just converted from vacuum to later model electric wipers. Bought a new switch from JBG and wired everything up according to VW's diagrams. Low and High work, but park doesn't. I think the problem may be in the motor. Does anyone have a picture of the park switch in the motor? I am thinking I may need to clean it.
JohnJohn
Richmond
I highlighted the area you want to shoot break cleaner at. It can be hard to see but you only need to separate the motor about a half inch then spray at this area.
If it does not work then take it fully apart and check it out.
Lunar-tic
Lunar-tic
Brentsville
Roger, I took the motor apart and the contacts were clean, but for some reason the cam wasn't pushing the plastic rod up to actuate the switch. I took it all apart and figured out that someone did the same thing in the past, but reassembled it incorrectly. I fixed it to where the plastic peg goes up and down as the cam functions, but the motor still will not park. I don't get it. Could I have ordered the wrong switch from JBG? Also, now that I "worked" on it I only get one speed not matter if the switch is on low or high. I guess I did something wrong when I was reassembling the brushes. I need a beer or two and a night to sleep on it. Thanks for the help.
P.S. I ordered this switch from JBG:15230A
Viperwolf1
electron whisperer
Make sure the switch is giving you the correct things at the connector.
Lunar-tic
Lunar-tic
Brentsville
Roger VW, before I took it apart I had low and high speeds, now just the one regardless of it being in low or high on the switch. I also have power (just used a test light) on all of the posts at the switch (except for the two washer posts) when it is in low or high position. When I wired it up I used your diagrams you posted to make sure I had it right. Low and High worked before I disassembled the motor, it just wouldn't park.
