wipers won't stop
rickcarl
The wipers on my 73 Bronco continue to operate after I turn the switch off. They'll then turn themselves off 2-3 minutes later. Is this a wiring issue or a switch issue? Thanks.
rustbucket
Switch. The switch cuts power to the motor, so if they're still moving, the motor still has power.
Viperwolf1
electron whisperer
There is a switch inside the motor for the park function. Could be a problem there or with the dash switch.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
When the wipers stop at the top of the windshield frame, they're "parked"
The park function of the motor allows the wipers to keep moving in their normal pattern until they reach the park position after the switch is turned off.
Since you made the motors (plural) comment, I have to start with asking if you have the stock wiper motor setup or a separate motor for each blade non-factory setup.
If you are running separate motor it is completely possible for one motor to back feed the other motor and keep it running through the park position. At which point the wiper will continue to run until they both hit park at the same time at which point neither can back feed keeping the other running.
Post a picture of the wiper setup from inside the cab. That way we can tell what we are actually working with instead of guessing that you have a stock wiper setup.
R
rickcarl
It's a stock wiper setup, one motor. My guess was the switch too, but I'm putting off sticking my head up under the dash to replace it. Any tips for replacing it? Take out the driver's seat? For now, I can just jiggle it. Thanks guys.
