k13evin
Just did a 3g upgrade and was sorting some wires under the dash. When. I touched the red with green stripes wire it was very hot. Looks like it goes to the ignition switch but I could be wrong. Any one ever have this happen
That means either there is some load going to each of the cool wires, or the one that's carrying all the load is thicker (lower gauge) than the hot section. ...and the black thing is a "splice". The wires are resistance-welded together, and then black rubber is molded over the weld. The "gold" wire is actually brown (Br 262) coming from the starter relay. Is anything spliced into that wire? Is it connected properly to the relay's "I" terminal? Look closely at the relay's case - it should have "S" and "I" molded into the plastic above the small terminals....those other two wires coming out the black round thing are not warm at all. Only the red with green stripe going to the ignition switch.
It's weird tho those other two wires coming out the black round thing are not warm at all. Only the red with green stripe going to the ignition switch.
So can I just remove it.
I find it odd the brown and red with gold stripe do not get hot at all. Nor do any of the wires coming off the coil.
That funky wire is the only thing getting hot.
So what would be the best thing for it?
