Wiring Diagram Early Turn Signal to Late
72_EB
66to77
Anyone have a write up for going from a stock '68 steering column and turn signal/horn/hazard wiring to a late '76 column with the hazard in the switch?
Is the late bronco hazard in the switch the same as the tilt column hazard wiring.
mike.l
Milwaukee,WI
Doesn't the late column have one contact for the horn instead of two like the early ones had?
You could install a relay to solve this.
eb66to77
Bronc'Ownly
NOVA
Hazard in the switch? Hazard switch came in the column starting '71 or '72, maybe. Also around this time the the horn went to a relay instead of a direct power so if you don't have that you will need to figure that out. Sorry not more help. I used to have the diagram online but my new shitty blog won't let me upload the diagrams due to being huge.
rob wilson
Flagstaff, AZ
Here is a cross ref chart I worked up when doing my new wiring. Might help.
