Wiring harness
'66U14
Hey y'all,
Got a question. Does anyone sell an OEM '66 Bronco wiring harness? Was thinking about going with the Centech from TOm's Bronco Parts, then I read, "uses GM-style sealed plugs internally". I want this think to be 100% factory, and the wiring's totally ***ed up. TO give y'all and idea, I smelled something burnin' yesterday, got in and turned the key and nothin' happened....
xcntrk
NOVA
I replaced my entire 66' harness with an aftermarket (Painless) harness. Nearly every connector is replaced with OE equivalent. I think the only one I had to repin/replace was reverse light, everything plugs right in (dash, lights, indicators, etc.).
The American Autowire company does have a separate division that only makes vehicle-specific restoration harnesses, but their numbers are so far fairly limited I think. But they might be worth a call anyway, just to see if they've dabbled in the Bronco end of that scene yet.
As mentioned, there were changes to almost every year EB's basic harness. They may have looked alike on the surface, but there were little changes here and there to routing and stuff that could make it more difficult. And yours being the first year? Oh boy...
So far Painless is the only one that offers an off-the-shelf replacement that at least uses the original Ford wire colors. Although it's patterned after the mid-'71 and later harnesses, which are TOTALLY different than your original '66's harness layout, it does utilize most of the stock type connectors as xcntrk said.
Probably well worth it, unless you're just completely stuck on a full-on religious restoration.
If so, you may be on your own and working with a custom one-off harness.
needabronco
Prescott/Farmington
I used a Centech harness and reworked it using the factory stock pugs where needed, I also rerouted and re-wrapped the harness to look stock. That was on my 71' so the harness was routed correctly. Your 66 will be routed differently through the firewall, but I would think you could find decent used replacement plugs in decent shape to use.
The other option would be to carefully take your existing harness apart, repair what's damaged and wrap your harness back up with harness wrap NOT electrical tape.
In my opinion either option above would give you a good stock or stock like harness.
I've installed Painless harnesses before and personally I think they are very expensive for what you get and they don't look anywhere near stock!
Coldbear
Springboro Ohio
I was at the Bronco Celebration in early Oct. I am in the process of rebuilding my 74 Bronco that is tired. I asked several people what wiring harness they would suggest and Centech's name came up often. Any named brand harness companies will probably work. But my order from Jeff's Bronco came in last week with a Centech harness and I couldn't be happier. I had a 71 Bronco catch on fire years ago at a Drive In and hadn't a fire extinguisher along. ( young and dumb). Believe me, if your unit goes up in flames, you'd be happy to buy a $650.00 wiring harness than go through losing a cherished Bronco.
Definitely words to live by.
The Centech has served many of us well. When do you get to jump on the project? Or are you already done?;D
And don't forget, don't throw any of the old stuff away until you're done!
chris-nc
Bronco Apprentice
I also have a '66 (Sept '65 build date), and I'm in the middle of replacing the entire wiring harness. I decided to go with the Centech, also from Tom's and it arrived last week.
Here some things to consider:
- fuse box moves to glove box - I patched the firewall before installing an insulation kit.
- driver side firewall pass-thru hole had to be enlarged - easy work with a 1 and 3/8 step bit.
- passenger side needs a new firewall pass-thru hole - same general location as the driver-side, just above the fresh air intake for the heater and near the upper corner
- I wanted to keep the headlight switch on the left of the steering column - I had to extend the wiring harness for that switch because the Centech assumes the switch will be on the right. It took about 3 hours to build an extension and solder/shrink wrap everything and put into wiring loom. Looks professional and I was able to keep the labeled wires at both ends.
- I have the dual electric wiper motor kit installed from Tom's already. The Centech kit comes with a new wiper switch and wiring as part of the harness. I'm currently trying to figure out what path I want to take. Re-wire to use the new Centech switch and wiring or keep the existing. Either way, I'm also working out a new location for the switch as the previous owner put it in the middle of the dash in a funky location. I filled the hole when I restored the dash, now need to determine how best to proceed. The Centech kit has the wiper switch on the right side of the steering column, so using the old washer button location is not really an option without more wire extending.
- When I laid everything out on the floor, it looks like the voltage regulator will need to move from the driver-side headlight area to near the battery on the passenger side.
- It does use some different connectors as previously noted.
Hope this helps.
Chris
Borinqua Bronco
Centech is an excellent option. I used it on my ‘74 and very happy. Same look and outcome as Painless and half the price. Good luck!!!
