eds66bronco
i'm getting ready to put the 77 harness back under the dash and need some help to identify some wires. i have the wiring diagram for the 77 harness i'm using but can not id one connector. it passes through the firewall in the center of the compartment and is a 4 pin connector. (kind of like the tail light/sender harness connector for the rear) it also has the carb solinoid valve wire. all the wires were cut and wire nutted by PO. it was pretty greasy but looked like two red wires and two brown or black ones plus the red carb wire. anyone know what this set of wires went to? i thought they might be the oil/water sender wires but i traced both of those back through the coil harness. ?:?
any ideas oh wise ones
