Airmapper
Foolproofness Tester
I did do a forum search, and I swear I read a thread on my exact issue but I can't find it now.
Anyway, I don't want to put in a full harness yet, but I do eventually. In the meantime however I need my brake lights, but am not sure where to start digging to find what exactly is wrong with them. I'm a bit lost when it comes to wiring, but I have a multimeter and can usually figure out how to use it. (I did blow one up one time, if that gives you an indication of my electrical skills....%) )
Everything seems to work, not perfectly but works, with the exception of the brake lights, and rear flashers. Turn signals and running lights do work in the rear.
My brake actuator switch is on the master cylinder, it's the manual pressure switch that has 2 pins on top and I did a continuity test with the multi meter on it and it does work (as it should, it's brand new.) To my knowledge there is no actuator on the pedal, I could not find one and think they used those starting in 67.
A wire to the rear running along the drivers side of the frame seems to be fine, but it is the only wire I see running back there. I'm assuming my issue is closer to the front?
Any help with how to diagnose this will be appreciated.
