Before I attach the battery and turn on the key to do an electrical test what precautions should I take?
Well, assuming you did this, but quadruple-check for any bare, unused, damaged, crossed wires or any that are close to something that's going to get hot with the engine running is a good start!
I have petronics points -will they be damaged with the ignition on and not running?
YESYESYESYES!!!1
For your initial tests just use the ACC position while you're checking 90% of the truck's electrical components. This leaves both the voltage regulator and the ignition system off and out of danger.
But once you need to turn it to ON to check ignition stuff and whatnot, don't leave it this way for very long. I like to use 1-minute as my maximum time limit.
There is very little you need to check with the key in the ON position anyway. Once you're ON and you know that there are no short circuits or melting components, fire the engine up!
One circuit you can test with the key ON and then START, is the starting circuit and the neutral-safety switch. But for that all you need to do is verify that you get no crank in Drive or any of the other non-start positions, and that you do get cranking in PARK and Neutral. All of which only takes a few seconds of key ON time.
Good luck. It's an exciting time in any builder's life!
