wobbly front End. Where do I start?
Gweiner
Charlotte
Help! Front end is wobbly/shimmying around 50mph. Planning to replace steering stabilizer but pretty sure rest of front end is original and stock. Any suggestions on how to help tighten up the front end so I can drive on the highway?
broncnaz
Need to get under there and see what is loose. could be ball joints, wheel bearings, tierod ends or just worn bushings namely trac bar bushings, could also be worn tires. Steering stabilizer probably wont fix anything it might slightly cover a issue but wont fix it.
Bulletman
Do a search on this site for Death Wobble do a lot of reading and you will see a trend of what you need to work on.
OK, start with the basics...
What tires?
How much lift?
How much caster do you have? (alignment shop initial alignment check). also the rest of the alignment numbers.
Steering stabalizer is NOT a fix to this problem.
My guess is that it was lifted poorly and the front end geometery is off (especially with "everything original" comment).
mofoco1
Clovis, CA
Mine was a combo problem not sure where it started and led to other stuff, this is what I did to solve death wobble, I had 38.5 TSL/SX x 5.5" SL but here goes:;D
1.Trac bar upper bracket( I added the Duff's drop bracket, welds failed, couldn't tell unless someone steered for you and you actually saw the bracket move.
2. The frame around the PS box had multiple cracks.
3. Ball Joints were replaced done before problem though.
4. Installed Steering dampener.
5. Installed new links all the way around, before problem.
6. All new bushings before problem.
7. In response to the ? New tire new rims and new disc conversion(79) new bearings properly tightened.
Hope this helps....Mo in Clovis, CA
G
Gweiner
Charlotte
Thanks guys. Looks like I have a lot to look at it. bronco is bone stock, except for 31's on the original Wagon wheels. Tires are old cracked and will need replacing but wanted to fix problem first before spending $ on new tires. Steering stabilizer has been leaking oil and is obvious needs replacement. Will look at bushings, tied rods" etc.
Bulletman
My tire will cause it on mine, I got everything in good shape and it still did it, until I rotated one side of tires with no effect and then the other side and it went away, mental note made my right rear tire has an issue.
Jeff76
Alpharetta GA
Make sure the wheels are not bent. Bad Tires and wheels can create wobble on a vehicle that otherwise might never exhibit those symptoms. Even just out of balance tires can induce that harmonic effect in newer vehicles. If you have to do it anyway, this might be the first place to start, at least eliminate a variable.
bknbronco
North Metro, MN
Start by taking off the steering stabilizer and dont buy a new one. Fix the problem before you go buy one.
Does it just wonder all the time or when you hit bumps and potholes??
Have somebody wiggle the steering wheel and see if any of the tie rod ends are clunking or poping or moving at all. Also look at the drag link ends while moving the wheel. Also look at trac bar ends while moving wheel. Then jack up one side just far enough so you can get a long pipe under the tire, lift up on the pipe and look at the ball joints and make sure there not poping or clunking or loose.
Do all that and then report back. If all is good then check air pressure. Start around 25lbs maybe. Then check toe in, set to 1/8"-1/4". Just remember that it will never drive like a cadi, it should drive well but never will compare to a new vehicle.
70_Steve
Old Guy
Quite a few here, myself included, prefer to not run a steering stabilizer. As has been mentioned here already, they tend to mask problems, and are never a cure.
The Death Wobble has been mentioned a couple times, but I suspect, if you're complaining about a shimmy at 50, what you're experiencing is not the Death Wobble. Death Wobble usually occurs at a much lower speed, like 15-25 mph, and would NEVER be referred to as a shimmy.
Do what's been suggested here, and have someone move the steering wheel back and forth while you lay underneath looking for play in anything. But with old cracked tires, you certainly can't rule out the tires as the source of the shimmy.
Fix the steering components, get new tires, and go from there.
