broncbuster
- Jun 29, 2008
- 414
This is going to be lengthy, Sorry in advance.
I have a 76. I'm doing a bunch of mods to the drive train/suspension/steering at the same time. I have been running 4.5" lift with stock 76 tie rod set up (properly adjusted toe in for the lift) and 7 deg bushings, stock radius arms, stock radius arm mounts, stock trac bar mount, stock pitman arm. It steered fine like this and tracked straight at all speeds even at freeway speeds. I was not really happy with the 76 tie rod setup, although it worked I know it's not really right. I wanted to go to a 1 ton tie rod/drag link installed TRO. I did not want to use wheel spacers. I was doing gears/lockers so I opted to go with a 74 front axle I had laying around and plan to do a chevy disc conversion so that I can run the 1 ton tie rod/drag link TRO with out wheel spacers. I'm planning on running Duff radius arms. I am also installing a 4x4x2 steering box at the same time.
So here's where I'm thinking I may have screwed up. I recently read that 74 axle housings (specifically 74's) did not have enough caster built into the axle housing and that 76-77 had a lot built in. I'm wondering if it steered so well and ran so straight because of the caster built in to the 76 housing. Reading up on and mocking up the Wild Horses Trac bar riser bracket it appears that the 75-down and 76-77 housings are different on the Trac bar mount. I already had the gears/locker installed in the 74 housing. The 74 housing isn't installed in the Bronco yet. I'm wondering if I'm going to have caster problems with the 74 housing. I want it to steer and track well (as it did before). I don't want to increase the caster a bunch with the Duff arms and 4-7 deg C bushings and in the process build in front drive shaft problems. I guess I can have the axle housing cut/re-welded to get better caster w/o pinion angle problems, but I really hadn't planned on going to all that hassle when I moved away from the 76 axle housing. Maybe I should have stayed with the 76 housing.
Anyone have any experience with this situation?
If I need to modify the 74 housing where can I get that done?
Will
Will
