Wont hold idle and dies
MR T's 1970
Johnston
So bought a project from a guy local.
He rebuilt the carb and did something with points and timing.
Runs great with foot on gas but dies right away when you let foot off gas.
bronco won't hold idle
302 2 barrel 3 on tree.
thanks
B RON CO
Statesville, NC
Hi, check for vacuum leak. Are you working on it yourself? Go over the tune up, including point gap and ignition timing. The distributor vacuum should go to the ported vacuum source on the carb. Get a Chilton's manual. Good luck
WheelHorse
Start by turning the idle screw in enough so it stays running without your foot on the gas.
texk
Franklin
Is the gas fresh? I had the exact same issue but added a bottle of Heet and it cleared right up. Sometimes it's the simple things.
Sent from my SM-G930V using Tapatalk
