Buldozer
Bronco Virtuoso
Yea, the idle mixture screws with it running should kill it. Screw them in until it about dies and when it about dies back them out until it idles... or in your case at least runs....
Sure sounds like you have a messed up carb or a bad vacuum leak and I will wager on the carb unless you have an EGR problem if that engine even has EGR on it... since the engine has not been apart to have the kind of leaks that would normally cause it not to idle...
You can always just go to the parts store and pick up a carb and see if thats the problem.... or swap one from another rig
