- Joined
- May 24, 2004
- Messages
- 3,413
I've been trouble shooting for a week now and still can't figure out my problem. I jumped ahead of myself and installed the DUI distributor during the Centech install before I cranked it using the original distributor & coil. After it didn't crank and figuring out that the new DUI didn't fit with the hood, I put the old distributor & coil back in. Now it won't start. The exhaust just puts when I turn the ignition. If I put enough gas it'll throw a flame from the carb.
First thought - the rotor is off 180 degrees. I turned it 180 and BOOM backfire from the carb, so it must be on correct where it was first (which is how I remembered it when I took it off also). So I've put it back to the original and still just PUT put PUT.
I can get a good arc from the coil wire, so the dist. is getting fire. The points are gapped correct (haven't touched them since it last ran a couple weeks ago).
What would cause this. I'm tired of killing my battery and just getting some puts from the exhaust. My timing should be close enough to start. When I took it off, the vaccuum advance was pointing straight forward and this is how I re-installed it.
Please help so I can get back on the road. Thanks.
