chickenman
Hi all, I haven't posted in a while but figured here would be the place that I could find the answers I need.
Background on the truck-
'73 with a 302, edelbrock intake carb and cam. I installed a painless wiring harness 6 years ago, an I have had no issues with the truck toll last night. Its been my daily driver for the last 2 months
I drove my '73 last night to work and came out 8 hrs later to a rig that wouldn't start(won't crank). I ubered home and went back today to see what the issue was.
there seems to be no power when I turn to crank. Radio works in the ON position but looses power when I turn it to crank. No blown fuses
I managed to 'jump' start it with a screw driver across the ignition coil posts and get it home. I swapped out the ignition coil and same issue, no crank
My next guess the the ignition switch is toast (original) and I need to just order a new one. It has always been a little sticky in the crank position and I need to make sure the spring returns it the I start the truck.
I pulled the ignition switch out to do a little further inspections and have had nothing but issues with it going back together, or being able to spring back from the crank position.
other than the switch that is now on order, are there any other thougts?
I appreciate the help
Dan
Dan
