66broncnut
I recently purchased a 66 EB with drums all the way around I have replaced every part from the master cylinder back but still don't seem to have proper brake pressure. I gravity bled first than bled each wheel individually I have all the brakes adjusted (if anything a little to tight). Seems like there is to much travel in the pedal before any pressure is felt is there an adjustment in the pedal I am missing or what. I am considering adding some sort of spacer between the rod from the pedal and the master cylinder. Any help would be appreciated. Thanks in advance
