Yet another question about BC's Spring Rockers
Dennis
Northern California
When there mounted up on the rearend spring perch. how much further in are the new "U" bolts. I'm getting ready to install an inboard shock setup and I don't want to weld the shock mounting tabs too close to the spring perches. Yet, I want them as far toward the tire as posible.
I would like to install the rockers at some point. Unfortunatly, there just not in the budget right now. I just don't want to re-do yet another thing on the beast.
Edit...
When you look at this pic, you'll see that they seem to be bending a bit toward the housing. From making sure they're nice and tight I supose. Is there enough room for me to cut a set of spring perches in down the middle and weld them to the rockers to prevent this from happening?
attachment.php
U
Unregistered
Guest
i have rockers and the cross shock hoop.. i don't understnd your question. If you do the rockers i would recommend changing the spring perches to the larger ones to min the axle wrap stress on the rocker. the inbound shocks need to be placed at a specific angle to max the effective use of the shocks
U
Unregistered
Guest
I mention the new perches because with the rockers you will be increasing the lift by about 2 inches and if you have a lift already this could make it around 5 inches of total lift. i recommend the perches be changed since you should change the pinion angle if it is excessive since it will cause increased u joint wear. There is larger perches available that will help to provide additional support to the rocker. I stress that this advice is not referring to any flaws or issues to the rockers. It is simply a suggestion to think about if you have to cut the perches off and reposition them for pinion angle correction.. like the guy said why redue to job when you can do it once and be done..
Dennis
Dennis
Northern California
I guess I may have confused the question. What I'm asking is where to weld the tabs on the rearend housing for an inboard shock mount. I plan on going with the spring rockers latter and I don't want to have to move them. I want to try and get the shocks mounted as far outward as posible and still leave enough room for the rocker install latter.
If I had the dimensions of the bottom plate on the rockers I could probably figure it out.
Madgyver
Bronco Madman
I removed my spring perches to rotate it a few degrees and also I needed to move the lower mounts inward a little because of the wider base the spring rockers have. If I were to do it again I would buy wider spring perches to mount on the axle housing for the spring rockers.
GRIZZLY
Lakewood, CA
Give BC a call. I'm sure they will give you the measurements.
chuck
Ingram, Texas
I do not had that measurment with me but call the shop or E-mail me and I will get it for you. The bigger perches are nice and cheap too. The bend of the bottom plate is caused by over tightening.
