I have a '94 351 roller engine that I'll be running with a carburetor. In my never ending research, I'm trying to figure out the correct distributor to use.
On the nearly new 351 '69 Mustang distributor I have (and was originally planning on using) the measurement from the bottom of the shaft to the gear is right at an inch. On the TFI distributor that came with the engine, the distance is 1.5 inches. Can I even use the shorter shaft in the roller block? If I need to use the longer shaft, what do I ask for and where do I find the correct distributor to use in a roller engine with a carburetor setup? I can't use the TFI distributor with a carb can I? At least I think this is a TFI. Please correct me if I'm wrong. I'm not super familiar with the EFI stuff.
