ZF5 rebuild
gunnibronco
Gardnerville, NV
I'm pretty sure my ZF5 needs to be rebuilt. It was a Craigslist score, that looked very clean and it was cheap enough so I bought it.
After my install, it leaked (badly) out of the front seal. I pulled the case apart and added a "Speedie Sleeve" and it sealed up. Since then I've had problems with it griding into gears despite the clutch pedal completely depressed. This happens on upshifts and downshifts as well as going into reverse or going from reverse into 1st or 2nd.
It rarely, but sometimes slightly grinds/buzzes into gear in 2 Hi. I can usually shift as quickly as I want in 2 Hi without any problem, but sometimes I can feel & hear slight gear grinding.
In 4 low 2.7:1 (Atlas 4 speed), I get more noticable grinding, when I shift quickly.
In 4 low 4.3:1 and low/low 11.7:1, I have significant difficulty making a clean up shift or down shift. If I let the motor completely wind down I usually can avoid grinding. This doesn't really work for offroading as the shifts have to take so long the truck will come to a complete stop before I can shift into the next gear.
I'm assuming this indicates bad synchros and/or bearing play making gear alignment slow/impossible. Is this a correct diagnosis? I assume the transmission shouldn't do this and I should be able to make fairly quick shifts (not looking for race car performance) without grinding gears.
Can anyone recommend a good source for a rebuild kit? I see a wide range of pricing and want to buy quality as the work will obviously be significant. I do have people familiar with rebuilding transmissions available who will help, I know the ZF5 is a somewhat difficult transmission to work with.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Take a look at this video, it does not look like a fun rebuild
Dave Chappelle from Dirt Everyday just swapped 4 qts of Redline MT90 into his ZF and it solved the grinding into gear issue and stopped the bearing rollover noise. I'm going to do the same when I put mine back into the Bronco. From what I've read, the ATF from ford was originally recommended by ZF for cold climates, and was originally a gear oil for regular/hot climates.
As far as kits go, this is the one I've seen recommend in OBS forums https://www.usastandardgear.com/sho...jBocVFYVRSC_vM9Wpj0BlIMGlV7PXxn_8m-5O6YLb9fCf
gunnibronco
gunnibronco
Gardnerville, NV
What fluid are you running?
Tim
Synthetic Valvoline ATF. Is the stuff recommended below better or something else?
edit: I just saw the Valvoline Synthetic ATF is approved as Mercon LV, not Mercon V. Is LV low viscosity? and could that be the problem?
I'll look up the Dirt Everyday video. I found it on his Dirthead Shed page. It would be great to just swap oil.
Thanks for the rebuild video, I'll check it out. I have read it is a difficult rebuild, but I have some very experienced friends willing to help. Hopefully a fluid swap will avoid the rebuild. Thanks.
Timmy390
Conway, AR
Redline MT90 is good stuff. I run "synchromesh" in my M5ODR2 and it shifts good.
Your issue sounds like a fluid issue to me. I would give the proper fluid a try before I rebuild it.
Tim
gunnibronco
gunnibronco
Gardnerville, NV
Tim
I'll check Synchromesh out and will definitely swap fluids before attempting a rebuild. Glad I asked here before tearing into the trans. I agree it feels like a thicker oil would help.
Sent from my Pixel 7 using Tapatalk
phred
Earth
I’m running redline MTF. The roll over noise is bad but it shifts just fine. I had the zf rebuilt about 5000 miles ago. Everything in it is new except the main shaft. I’ll probably change to mt90 at 10k to help quiet it down some.
gunnibronco
gunnibronco
Gardnerville, NV
I've ordered the MT90. I'll update when I get it swapped in. Thanks for the info.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I've got the bottles of it ready to go. I want to redo my trans tunnel so you'll probably get a chance to try it out before I do.
gunnibronco
gunnibronco
Gardnerville, NV
I drained the trans and refilled it with MT90 and took it for a quick test drive. It shifts better and grinding was greatly reduced, but not totally eliminated.
It seems it's shifting very well between 2nd and 3rd, even in the 4 low gears (2.72:1, 4.3:1, and 11.7:1).
I'm still getting grinding between 1st and 2nd in the 4.3:1 and 11.7:1 low gears. I was testing it with a "worst case scenario" running the RPMs up around 3K and shifting quickly. Do I have unreasonable expectations of these types of shifts? There is a significant drop in gear ratio from 1st to 2nd (5.72:1 to 2.94:1), it does occur to me that it just won't shift quickly between those gears. I can modify my driving style to adapt if needed. I just don't have experience with any other ZF5 to know what to expect.
I've watched several ZF5 rebuild videos and it seems within my capabilities to rebuild it myself if needed.
gnpenning
Bronco Slave
As you know these are truck transmission and not a race car type shifter. RPM, ground speed are important to a smooth shift. If everything matches you should be able to shift up and down the gears without the clutch. Yes, I know it's not for everyone or every shift, just reiterating the relationship of RPM and ground speed.
Drive any heavy truck with a manual you should be able run the gears and only use the clutch when stopping and starting out.
The end play should be measured before tear down and matched upon reassemble.
I don't know how fast you are trying to go through the gears, try slowing down and see what happens. It sounds like you are trying to row through the gears?
gunnibronco
gunnibronco
Gardnerville, NV
That's my thoughts as well. This might just be what I should be expecting.
The transmission that's in question was a Craigslist score of unknown condition. I doubt it was ever rebuilt. I'm trying to decide whether or not to rebuild it. Obviously I don't want to do a rebuild if it's not going to improve the performance.
onpier55
Roseville Ca
I rebuilt my CL Zf5. Bought my rebuild kit off eBay. Make sure they advertise no Chinese bearings. There are only three videos on YouTube that are worth anything. All three give great advice and different tricks. I replaced all bearings and synchros. I had to replace the reverse gear and syncro slider. They did some grinding. Lol. I did the trick of adding an extra qt in thru the shifter. No rollover noise. I’ve put about 1500 miles on it so far. Excellent upgrade. I can answer any questions on the rebuild as there are a lot of tricks to prevent yourself from buying a lot of tools. I made setup bearings for checking end play. Pain in the arse putting it back together only to take it all apart. Lol.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Glad to hear the MT90 is working out for you. As for the speed of shifts, I always wait until it feels like it's ready by applying a little force into the next gear. When I feel the synchros align then I shift. It's not a quick shifting transmission, took a while to get used to coming from T45 and T56 equipped mustangs lol.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
For anyone that searches this, just drove the Bronco with MT90 swapped in and it shifts better than it's ever shifted. I'll circle back in a month or two and report any news.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
It made it significantly quieter. I drove the Bronco with my transmission cover removed and I could barely hear any rollover noise whereas before it was loud with the cover installed. I can borderline "shift fast" (fast for a ZF, normal for everything else) without grinding. I'm trying not to exaggerate, but it honestly feels like a new transmission with the limited driving I've done.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Update: The fluid still works great, the synchros are a little sluggish on startup, but once there is some temperature in the fluid it shifts great. 10/10 recommend MT90 over the ATF for ZF.
