ZF5 twin stick fit problems
csangster
I have the BC bronco adapter for the ZF but the wild horses twin stick setup.
The twin stick mounts to the rear threaded hole on the driver side of the output housing.
I have the tcase rotated up so the forward drive won’t hit the crossmember.
The linkages supplies in the twin stick won’t reach.
Should I extend them? Relocate my shifters? (Looks like BC and WH do it differently
Thoughts?
Chris
Timmy390
Conway, AR
While I haven't done the ZF or M5ODR2 swap yet I have an R2 sitting in my shop floor and have been gathering information on the swap.
Here is a thread with pic's that explains what you may need to do.
https://classicbroncos.com/forums/showthread.php?t=218602
Also if you go to the JB Fab website it lists specific sets of twins for the ZF and "J" to "T" shift. Not sure what the difference is......
Tim
jmangi62
Like Timmy said,go check out JB Fab,or better yet give them a call and explain what you have, they're the best for twin stick stuff.;)
JB Fab
Do you have a "T" type or a "J" type?
Check to make sure the AA Bracket is straight, I have seen some that are not.
C
csangster
Group,
Yes this is the right way to do it...….
The threaded boss on the side of the case is stripping. I'm a little surprised I didn't get this bracket in my kit from BC broncos...….
Thanks,
Chris
