Front outside(drum) brake lines r & l side brand new not ( SS ) never used $20
Wiper motor and bracket $20
jack hold down strap $4
rear tailight bezels look like spun aluminum not chrome no dents $15
28 spline axles bb 9" ask which side if your interested $10
(2) Dana 20 transfer cases J shift $35 each
(2) 3spd trannys ran $20 each
pair of stock rear leaf springs \no shackles free
manual flywheel 6cyl $10
Bellhousing sb ford $25
ash tray $5
driveshaft front no cv joint $10
Wiper motor cover with light painted black $15
wiper fluid box $5
hood props $5 each
3 on the tree 3spd linkages $10
Gas pedal $5
clutch parts; fork $10
pivot lever or swing arm? $10
hood spring $5
hood release and lock bracket $8 each have
rear brake drums 10" off road only can't be turned any more but they will work $10 pair
1 front brake drum $5
off road drum hubs $10 pair
original steering wheel cracked but usable 74 $10
wiper motor bracket $10
Misc u- bolts $10 set
Send private message please
ash tray $5
wiper fluid box $5
hood props $5 each
Gas pedal $5
hood spring $5
