The tie-rod "flop" motion is likely also what killed your dust boots earlier than normal. However, I have to say that the usual caveats apply to these parts too. The modern (mostly chinese built) products just don't last. Where an old rubber dust boot might last twenty years before splitting or falling out, the new ones last maybe a year. Or two if you're lucky.
The polyurethane ones from the usual suspects are made in the U.S. but if they are a too-tight fit they will likely fail quicker than they would if they were a better fit.
And if they're tight, the tie-rod-roll (or "flop") is just going to make that happen even sooner.
Since it hasn't been mentioned in this discussion I don't think, I'll bring back up the reason for the extra roll when using the GM-based parts is that these tie-rods were never designed to have a draglink pulling up and pushing down on them. The tapered hole we use for the draglink was originally a mounting point for a steering stabilizer shock. The GM vehicles that used this type of product had a short draglink connected to the driver's side steering knuckle (via a bolted-on steering arm) and the tie-rod simply connected the two knuckles.
The stabilizer hole was simply made this passenger side rod end a convenient swap part for those wanting a custom steering setup for their Broncos.
If you compare the vertical orientation of the lower draglink interface compared to the original Ford orientation with about a 60° rotation from this point, you can see how Ford tried to minimize the roll/flop action.
Probably too why the lower draglink dust seal was a different design and included a metal protective washer/cup/thingy.
