16" factory option Bronco steel wheels and tire options
Beer and Fish
I have miraculously acquired a set of (5) true factory K/H Bronco wheels 16" I am going with a Wild Horses 3.5" suspension lift and a 1" body lift on the build. What would be the tallest tire I could run on these very narrow (5" I believe) wheels? Please provide me with available sizes that would look nice and compliment the build. 33" or 35" would be best and the Bronco is a 1975 uncut body. Thank you in advance!
*NO THE SET OF 16" WHEELS ARE NOT FOR SALE!
okie4570
NW OK
LT235/85r/16 are fairly tall (32" iirc), and they are skinny. I have a set on my crusty 66' u15, street tread.....mud tread looks much better but could pas up the deal on the street tires. They may not be tall enough for 4.5" lift though.
You should measure them (inside the bead) just to be sure of the width. I would have thought them 5.5-6 inches wide, but I've never had a set in my hands to check. Maybe there are even some markings on the back to indicate the size?
If they are 6 or 6.5 inches, a 255 would fit pretty nicely. Might even fit a 5 incher. A 255 is getting pretty close into that 10.50 range. But an 85 profile can be the equivalent of a 35 inch tire. My 255x85-16's are 33.5" tall, which matched my previous set of 35x12.50-15's.
Might still have to move the rear axle back a bit to avoid that pesky leading edge of the rear wheel opening, but with over 4 inches of lift, a 35 is not out of line.
Look up member 1sicbronconut here and check out some of his pics. I forget what tire size is used, but it's got some good size tires tucked up in some nice suspension twisting shots.
okie4570
NW OK
They are listed as 16x6.5 but I've never actually measured one.
ford man
Leesburg Ga
Hey I know a guy in south Georgia that would buy them wheels from ya! I would say back off the suspension lift to like 1.5 or 2.5 at the most and put some 750x16 or 235x85x16 .I would guess that 255x85x16 would work but I would think it might have some tire roll or side wall flex that could get to be dangerous.I know that some one like Stockton wheel can widen your wheels or build you a new set to look like the old ford wheels maybe an option. Here is my bronco with 2.5lift no body lift and 235x85x16 BFG mud ta.
trekgurl
I saw Ford Man ‘s setup sometime in the past and I liked the skinny look. So, I went with a Cragar Wheel, Soft 8, Steel, Black, 16 in. x 7 in., 5 x 5.5 in. Bolt Circle, 4 in. Backspace.
I did the same 2.5SL, but I did a 1” BL..
Same tire
Size​
Diameter​
Width​
Tread Depth​
Tread​
Rim Width Range​
Load range​
Max Load​
Max PSI​
Weight​
Revs Mile​
LT235/85R16​
32”​
9.3”​
18/32”​
6.5”​
6-7.5”​
E​
3042​
80 psi​
50 lbs.​
650​
BradinEDH
Newbie
I have the same Cragar soft 8 16x7 wheels with 4" backspacing. Tires are 255/85/R16 KM3s. 3.5" lift and 1" body lift.
IMG_2475.jpg 711B16D8-BCC7-4286-97D2-06767E59F7D7.JPG IMG_2466.JPG IMG_2468.JPG
trekgurl
interesting,,, so searching 255/85R16 tires, its saying its a diameter of 33.1", section width of 10.0", wheel diameter of 16". circumference is 103.8" 610 revolutions per mile. approved to be mounted on 6.5-8" wide wheels. You got a 3.5 SL. so that means your 2 inches taller at the seat than me.. I'd like to crawl under that and see what the clearances look like....skinny ain't for everyone, but I like it.
ford man
Leesburg Ga
trekgurl
Trekgurl your looks good too the top always reminds me of and old airplane.
yeah,, wouldn't be mine if I didn't do something bat sh-t crazy too it :), I was thinking of a hood made from scratch :rolleyes:, the same way lol,,, or wait until I get my on board air system done, :)
Beer and Fish
Beer and Fish
So if I go with a WH 3.5 lift and a 1" body lift what would be the tallest tire I could put on these wheels?
31, 32, 33, 34, 35.
Are the lifts already installed? Measure between the leading edge of the tire and the leading edge of the rear wheel well opening. All around the curve.
That will get you pretty close to what your particular bronco will fit.
Don’t know if we have ever compared Broncos to see why this is, but some seem to have their rear axles further forward, or bodies further rearward. Putting tires closer to that body panel than others.
Bronco_007
Nature Coast, FL
Same tire
Size​
Diameter​
Width​
Tread Depth​
Tread​
Rim Width Range​
Load range​
Max Load​
Max PSI​
Weight​
Revs Mile​
LT235/85R16​
32”​
9.3”​
18/32”​
6.5”​
6-7.5”​
E​
3042​
80 psi​
50 lbs.​
650​
Get any rubbing?
