aelkhunter2$
- May 8, 2016
- 2
Power Steering – Power disc brake (Front disc & rear drums all New. – New power brake unit & master cylinder –New timing chain, cam gear & crankshaft gear – New Melling oil pump & screen – New water pump – New 4 row aluminum radiator – New thermostat – New mechanical fuel pump – New alternator – New gear reduction starter – New crank seals front & rear – New rear axle bearings (large bearing) & axle seals – New air conditioning system – Updated headlights – New dash pad – New turn signal switch – New cruise control – New seats front & rear & new carpet front & rear – New 23 gallon fuel tank – New 3 point seat belts front – New seat belts rear – New rear pinion yoke & seal – New radio & speakers – New hydraulic props for the hood & rear window – New Warn Premium Hub locks – New steering wheel – Wiper delay switch – New 2 ½” exhaust from front to rear – New tires 5 each Toyo P265/75R15 Open Country A/T (Less than 700 Miles Trued & High Speed Balanced).
REBUILT THE FOLLOWING: C4 Transmission (New Flywheel) – Transfer Case – Carburetor – Front & rear Driveshafts w/new CV Joints & U-Joints & Balanced – Re-arched rear leaf springs and added one leaf to each spring with all new bushings – Complete rebuild of front end (Coil Springs – Upper & lower ball joints – All Tie Rods – 100% of the bushings – New Monroe Shocks front & rear.
I have added other small things as well.
I have spare parts as well. I have the Original Front & Rear Seats – Air Cleaner Assy and other parts.
The Original Owner had to replace the Left Front Fender due to a mishap.
