Mtymse63
- Joined
- Apr 15, 2014
- Messages
- 48
Per the title, I'm trying to retain as much "Survivor" status as possible on my barnfind. Have slowly continued to uncover and discover more work and goodies (found the original build sheet under OEM mat)...will be in the market for some chrome bumpers based on sheet. Let me know if you Gurus see anything else glaring on the build sheet as I've not been able to track down all codes.
Would like recommendations as to what I should do with the floor pans and firewall panels given the condition. This will be a sunny day driver so hopefully won't be seeing too much moisture. Should I replace pans and panels or repair rust and Ospho rust areas? I'm sure I will need to replace someday but don't want to hurt "Survivor" status if possible. Truth is I've had to replace master brake cylinder, carb, and front springs to get functional.
