Yes, thanks redwards.
I was able to take the hats to a local machine shop to custom fit them to the Solidaxle Dana 60 hubs. Which are a little on the bigger side than stock FYI, so had to bore them out.
From there I took them to another local shop and had them hard anodized black to offset the colors a little, same company that Wilwood uses
From there, I had to find the right Dorman wheel studs to work on these specific hats and hubs. It was a pain in the ass because I originally was told to get 610-289, but in actuality they were 610-180. I had to shave down the wheel stud heads in order to fit inside the bolt head seat...that took at while.
The longer stud was the correct one. "610-180"
Once I had pressed all the studs into place and seated into the hubs, it was time to figure out caliper bracket location. Since the rear axle did not come with any flanges, I had to improvise and order the ruffstuff 14 bolt weld on flanges.
Once received I had to grind down the inner tabs to the size of my Currie 9" rear axle. I then had the caliper brackets custom made to fit this set up. The tricky part was making sure the offset was correct. So that the flange,caliper brackets, rotors, brake pads all fit accordingly.
These pics are before I corrected the offset.
I wanted the Wilwood calipers to stand out more, so I returned the black calipers and got the Red ones instead. From there I started to work on the front axle.
What do you think?
First up, was to piece together the Dana 60 Kingpin kit. Also, the brackets were different in the front compared to the rear, so I had to re-do steps from above to make sure the offset was correct. The brackets needed some massaging in order to fit on the hubs and around the spindle.
Since everything is getting mocked up for clearance check, I haven't completely installed everything. I wish I could take the jack stand off and have it just sit at full bump. I know jsmall was loving the feeling.
https://vimeo.com/195686527
Next will be the ruffstuff high steer link kit.
I can't wait to clean this thing up and show the bling, the surface rust it so annoying.
