Hoping someone with their Dana 44 with known caster can shed some light on the subject. Measuring from some easy to repeat locations for you to get to your goal.
I think James Roney had some hard numbers not long ago, but don't remember if they were something that could be transferred over to another rig without some head scratching.
It's a straight sine function. The radius arm is fixed length at 32 inches. At static ride height, (zero lift) the arm is nominally horizontal.
So, for caster correction, the numbers are as follows:
1 inch lift = 1.8 degrees
2 inch lift = 3.6 degrees
2.5 inch lift = 4.5 degrees
3.5 inch lift = 6.3 degrees
4.5 inch lift = 8.1 degrees
5.5 inch lift = 9.9 degrees.
The total angle between the caster axis and pinion inclination is 12 degrees. It's always 12 degrees. In the dozens that I have measured, its 12 degrees. Lots of people tell me that it isn't 12 degrees, and that all Bronco's are different. Yet, when I get them in the shop, and I measure them...they are all 12 degrees. 8 degrees on the pinion, and 4 degrees of caster.
The reason why this becomes an argument is because of the caster specification. The 1969 Ford Truck Service Specification Manual on page 3-26 states that the target caster is 3.5 degrees. That is for a manual steering, bias ply, 6 cyl station wagon on a ranch. The notion that the same spec is correct for a 70 mph highway cruiser on 33 inch radials with power steering is just plain silly. But I have seen it countless times, and will no doubt see it again on this thread. SOMEBODY will say that the factory caster was 3.5 degrees, and then someone else will say how 3.5 is adequate. And the debate continues.
Since no one is handing me an ice cold beer, and since I am not sitting by a warm campfire, I am reluctant to enter the debate. But I will say this:
1. 3.5 degrees of caster is the WRONG spec for a 93 inch wheelbase live axle bronco on 33's with radial tires.
2. I don't give a hoot about how much angular deviation (u-joint angle) you think is acceptable. Dana Spicer, Neapco, Precision, etc...all indicate that 1 degree of misalignment is preferred. For high speed, continuous operation, it's 1 degree max.
3. Every Bronco that ever left the factory and drives over 50 MPH needs more caster.
4. You can certainly get by with caster correction by installing c-bushings, and living with a kink in your driveshaft. If you never put your Bronco into 4WD on the freeway...it will work just fine right up until it binds. Lots of people do this.
@gtme1996 your specific answer is as follows: (and BTW, I like the 2 degree poly bushings, because they have shoulders and don't squirt out like the factory rubber ones.)
For a 2.5 lift, 35 inch radials, power steering...needs 6 degrees of caster. Factory was 3.5, -4.5 for the lift, +2 for the bushings, = 5 degrees of additional angle.
For a 3.5 lift, the answer is 7 degrees of additional angle.
