Dana 30 king pin rebuild help
Change in ride height at some point?
Original springs sagging or new taller springs?
What is the history of this Bronco and what else have you done to it?
sprdv1
REBEL
I called the tech at Jeff's Bronco graveyard after i too had the same problem.
I also installed the kit witout the spacer , dampener and cup with the kit.( just the race,bearing and seal & old cups) ; however , the tech at Jeff;s BRONCO Graveyard insisted that the kit would work with the 1966????
maybe they can walk you through it
Boccanegra
Looking for a knowledgable Bronco mechanic in Orange County, Calif. I have a 1970 and need my king pins and Dana 30 seals rebuilt.
Hytech
Going through the king pin install issues now on a 67" (per vin#) D30.
Where or from who can I find the Dana factory service manual ?
Are there an Id# on front axel to determine year of housing?
Are there any Differences in a 66 vs 67" housing?
Thanks .
