Bronco Gurus,
I'm rebuilding my Dana 30 King Pins and dampeners and I'm struggling with them. These don't make sense. I must be doing something wrong.
I've followed the diagram on the Wild Horses website, but things don't seem to be lining up. First question, is the bearing run supposed to be pressed on against the cup, or above it. Second, if I install the dampener and washer, then the bearing isn't making contact with the run. It sits above the run. Third, is the dust cap supposed to sit flush when it's installed? It seems to sit up too high. Also, should the bearing move around under the dust cap?
I've got them together, but don't have any confidence that they are correct. I'll upgrade to a 44 at some point, but this will have to work for now.
Thank you,
Clint
Thank you,
Clint
