Yes and no..... None that match exact.... You can go 78-79 bronco, or 70's- f150's.... They are approx 3 inches wider on either side, so you'll have to either go full width, or have the d44 chopped down to early bronco specs....
There's pluses and minuses to each....
Either way you get disk front....
Full width=added stability.... But needs fender flares.... You can turn lock to lock w 38's and not rub the radius arm...Tires likely to hit trees/rocks etc b4 the body
Downsides.... No longer factory...
Does take some fabrication, but not much....
I am here:
http://tapatalk.com/map.php?4ztzqc
1966,351,m5od,205....3.5" lift, 2" body, 35's,
