here is the motorsports manual
http://documents.clubexpress.com/do...3I8HbUztpYDYLORFevg+gnQE6Xv5gxu7jEs6s2VLTpAs=
lot of good ideas thrown around here & there but again it comes down to exactly what to do and where.
you will find wire colors vary harness to harness.
here are the basics.
strip down harness, zip tie loosely at all branches to keep shape
Inspect all wires including the factory splices
Inspect all connectors , tabs & locks get broken, the EEC connector plastic get brittle with age and the pin lock will break. learn how to unlock & remove pins, get spars at the junk yard
replace all the ford connectors you need to connect to your vehicle with weather packs, usually just the green one ant the one with the oil & water in it
identify what will not be used ( tab,tad, egr, purge AC wot) either remove completely or trin back to a central location & terminate with resistors so codes are not throw.
remove all fuse links replace with fused relays, share the load probably does not matter what is shared, but think about sharing same type of circuits.
Install harness into vehicle to figure out where your putting stuff & routing ( computer, fuse block, relays)
read and understand how to wire the NNS pin 30
http://classicbroncos.com/forums/showthread.php?t=172541&highlight=pin+auto
salt & pepper connectors, I usually clean & inspect them and put on conductive paste, I have removed them also, both way work IMO
Make a good common ground somewhere and run all you grounds to it.
I use these:
http://www.delcity.net/store/8-Point-Junction-Block/p_801580
when you done test it before warping up the harness
use harness tape and loam to wrap up the harness NOT Electrical tape, RJM sells it 3 rolls will do it get 5 just in case.
RJM harness is a good deal, all new parts buy it and drop it in.
I would not spend any money on paying someone else to rework an old harness figure $300 rework + $100 avg for a used harness you might as well buy an RJM harness.
cost of reworking a harness your self is about $50-75 for parts + free time, weather packs, loom, tape, fuse block, misc wire, ground blocks
