Not yet unfortunately. I keep thinking we should at least carry the canisters, but we don't. And I'm not really certain that the condensing tank is reproduced.
Seems like I saw one recently, but can't remember if it was new or used.
But there is an upgrade that's even easier than replacing like with like. And that's going to the '76 and newer style that eliminates the tank from the interior. In '76 and '77 you see all the trucks getting rid of their in-cab tanks and going to gas doors instead of extended filler necks sticking out. Regulations that did made sense.
You can purchase the newer style at just about any parts store or Summit or wherever. You need to mount it to the firewall (higher mounting is better) over on the passenger side where Ford put it in '76, then plumb just a single line from each tank to a "Y" fitting somewhere underneath, then up to the small port on the canister.
From the canister run the large fitting to the air filter housing and you're basically done.
The second large port gets a breather cap to keep debris and water out of the canister.
Other than that, I'm not sure that the original design parts are available anymore. That would be either a junkyard junket, or someone in the classifieds selling their old ones.
