Benzo
This is what I did with the front.
First do some preperation and make sure the frame horns are free of any old metal welding, hooks, and bolts. (It's always fun to get the grinder out )
You may want to make sure you have all the bolts, washers and nuts for the job. I needed a few more pieces and needed to go to the hardware store.
Follow the picture diagram Cary posted and insert the bolts into brackets on the bumper and snug up the bolts on the brackets. Do not tighten them too much because you will want to adjust the hight of the bumper later. Hand tight is good. This takes a little time. It's a fun simple puzzle.
Once the frame brackets are on the bumper, place the bumper on the frame horns. For safety, you may want someone to hold the bumper while you go under the bronco and put the two top bolts through the top of the frame. Finally, add the lower frame bolts and then add the side bolts.
When the bumper is loosely fitted, you can adjust the bumper where you want it. Tighten the frame bracket bolts on the bumper. Finally take it off if you weld the frame brackets to the bumper. If no welding , tighten all bolts
