Okay, I've read all the caster threads, and now I'm worried. I have a 69 Bronco with a Dana 44 that I purchased around 8 years ago. I finally got around to stripping it down to the frame and rebuilding it from ground up. However, when I completed it the first time, before a shitty body shop left it out during a hurricane, it was all over the road. I had already converted it to power steering, put in new ball joints, purchased the adjustable track bar, new radius arm bushings etc. This thing was straight up all over the road at higher speeds, and the steering never returned to center. I finally measured my caster and it was around 4 degrees positive. I figured it was because of my lift kit. I THOUGHT it was a 2.5, however after pulling the body off, I realized its a 5.5" lift kit that was running the stock radius arms. I purchased the drop radius arm brackets from here, and welded them on. I have reassembled my drive train, and just out of curiosity, I remeasured the caster, and its 9 degree postive on one side and 10 positve on the other. How screwed am I? Everywhere says 10 is too much, but I'm hoping not. I do not want this thing to rattle, but I also do not want it to wander all over the road. Prior to adding the drop radius arm brackets, the damn front springs were bowing out forward, however, after the bracket install, they are perfectly vertical, so I assumed it its on point.
I know my front pinion angle is off now, but I'll cross that rubicon another time. What do you y'all think?
Edit: when I first got it up and running, it rattled terribly, but it ended up being the rear pinion angle was off by 4 degrees. I fixed it, and all of the rattling stopped. The draglink, tierods, and trac bar are all aftermarket adjustable from wildhorses. Trac bar and drag link are perfectly parallel.
