Is there a cable clutch kit that works with our Broncos?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I know you can do a hydro clutch swap, but what about a cable conversion?
Seems like it would be an easy way to address the missing linkage hole in the later blocks that get swapped in. I've never heard of an EB kit though.
Anyone know if the Mustang kits work on the EB or if there's a universal kit that'll work?
Never seen one for a Bronco. Never seen one swapped in either, I always see conversions done hydro.
I know that motorcycle clutches can be hydro or cable, there are plenty of kits to upgrade old cable clutches to hydro, but never go from a hydro clutch to cable.
Crush
Greenbottom, WV
Buddy of mine did a 69 mustang using an 80's to 90's stock mustang one but i dont know what he did. Shouldnt be too hard to do
thegreatjustino
thegreatjustino
Stockton, CA
I have a cable conversion on my '67 Mustang, but it was already installed when I bought the car. Not sure what all the Mustang swap entails.
charlie6976
Grand Coulee WA
:My 76 Mustang II Mach I 302 4 speed had a cable clutch from the factory. Maybe research this as an option. Could be something overlooked. Maybe this helps.:)
This 76 had every Cobra part but the name.
adj. shocks, whole car blacked out, fast back,
302 v8, 4 speed, l/s rear end, ...and cable clutch.:eek:
Basketcase
Cable clutch
I have a cable clutch in my Mustang that I changed over to a T-5 transmission. All of the cable clutch set ups that I have ever seen are built to pull on the throw out bearing lever rather than push on the lever like the original clutch systems. That is because these are all using a Diaphram type pressure plate rather than a Borg & beck type plate. The throw out bearing on the Diaphram type rides in continuous contact with the fingers of the Diaphram and therefore require less distance of movement to actuate the pressure plate. If you are converting your clutch to a Diaphram type pressure plate you very well may be able to adapt a Mustang cable kit to your clutch pedal. Do a search for MustangSteve who builds a very good kit and may work for you.
