No. When using an Explorer front accessory drive, you must use ALL of the Explorer stuff. From the removal of the old fuel pump eccentric from the cam gear, to the front timing cover, to all the stuff that bolts on to it.
Part of what makes the Explorer stuff so compact is the unique parts to the Explorer and maybe one or two other vehicles. The water pump, alternator and power steering pump are only going to be Explorer, except in the case of adapting the Delphi/Saginaw power steering pumps to the Explorer brackets.
So while the old stuff will in fact bolt right on to the front of an Explorer engine, you'd be using it all, right up to the old pulleys and v-belts.
If doing that, you'd then need to have your harmonic damper re-balanced to 50oz in order to be compatible with the rest of the engine when using v-belts. As well as using a compatible flywheel/flexplate setup.
And if using a mechanical fuel pump (can't do that with the Explorer front stuff) you'd need to add the eccentric to the front of the cam gear, if that's possible?
