bluebronco69
soooo since i found the aux tank has a massive crack in it, i dont really want to use it any more... i was thinking of making my own higher capacity tank... what i was thinking of doing was taking 2 factory rear tanks, cutting them... and putting them together. is this essentially how the aftermarket tanks are? it would be mainly taller, not wider. the first tank, would have the angled bottom cut off and the second tank would have the top cut off then both welded together.
any thoughts? and of course if you all think this is a good idea, i need to find another stock rear tank in the Portland area
